Hi Raman, there is no direct way to do this, there are two things you can do.
While using Query data in the Celonis module use the filter option that is available there
Set up filters in the path
hope this helps !
A
Anonymous
Dec 2, 2022 8:18 AM UTC
hope this helps !
Hy Abhishek,
Ya it was helpful,
Also one thing I wanted to ask is that, I want a column in query data of action flow, to be filtered by kpi selection in views
I guess variables should be used here ?
So when we click a KPI, it filters a table below, but it should also filter a column in query data of action flow
example -: there is a KPI -: best performing agents and the logic is agents who attended calls over 40 per day,
so when I click on that KPI, only those agents will be visible in table below it and count of calls they attended in front of each and then I send data through email using skill
but the moment I am going to click on another KPI and the table is filtered but action flow or skill is still taking static filter, I want that to be dynamic
A
Anonymous
Dec 2, 2022 8:19 AM UTC
hope this helps !
I was thinking of passing column id of a table of views in action flow filters but I guess that won't work,
Yes you can just have to put your actions in KM, your identifier can be what you want to send etc.....
A
Anonymous
Dec 2, 2022 3:08 PM UTC
Great alternative actually
But can't we do this using those action buttons ?
ya identifier column will be sent as separate emails, but the kpi in front of each value of identifier I had to aggregate in action flow using group by option in text aggregator, but now I want this clickable kpi filter on that aggregation
At CeloSphere the knowledge model trigger for action flows was announced. It will soon be possible to add the KM logic such as filters and KPI to your action flow.
