How to use TODAY() function inside WORKDAYS_BETWEEN()?
  • Jan 9, 2026 11:59 AM UTC
  • 375 views
andres.naran12
Level 8
Forum|alt.badge.img+10
Hi community.
I have a question regarding WORKDAYS_BETWEEN function, currently, I’m trying to get the number of workdays between the creation date of a ticket and its current date, according to Argentine calendar. This is the PQL I have so far.
WORKDAYS_BETWEEN (
"XXXX"."fields$created",
TODAY(),
  FACTORY_CALENDAR(
            "FACTORY_CALENDAR_ARGENTINA"."START",
            "FACTORY_CALENDAR_ARGENTINA"."END"
For some reason, the PQL doesn’t return any results for any case. I tried this calculation with other functions like DAYS_BETWEEN instead, and it works. However, I need to take into consideration only the Argentine workdays.
I’m not sure if WORKDAYS_BETWEEN supports the TODAY() functions. Has anyone faced a similar problem?
Best!
abhishek.chatu14
WORKDAYS_BETWEEN  supports TODAY() function , can you help us understand what are the details in your  FACTORY_CALENDAR_ARGENTINA table ?
This is how you can test if TODAY() is the actual issue
WORKDAYS_BETWEEN (
TODAY(),
WEEKDAY_CALENDAR ( MONDAY TUESDAY WEDNESDAY THURSDAY FRIDAY ))
andres.naran12
Level 8
Hi Abhishek.
I did your test with your recommendation using the WEEKDAY_CALENDAR instead, and it is able to calculate the number of days between both dates. However, in this case, I need to use the FACTORY_CALENDAR since I need to take into consideration only the Argentine workdays, I mean weekends, and holidays should not be taken into consideration.
I normally use this calendar to build other KPIs with other date fields and work without any problem, but not with the TODAY() function. I have the start date and end date in this format for the FACTORY_CALENDAR:
This is a brief example.
I hope this helps to have a bigger picture.
Thanks!
