How to navigate to another tab in same view using button click of user?
  • Jun 19, 2024 4:27 PM UTC
  • 166 views
gauri.pai11
Level 3
Forum|alt.badge.img+3
Hi team,
I am searching for a component which on clicking will take me to another tab in same view.
It was possible in analysis using button component (open tab feature).
Can you please guide me how can i achieve this in view.
Thanks beforehand for the help.
Hello!
If I uderstood the question right, your objective is being able to access another tab in the same view when the customer clicks a button.
I don't know exactly the specific use case that this is intended for but maybe this can help. Use a "button" element, then, go to behaviour > on click > open view in overlay. Then, just create the tab you want the customer to be able to access as another view and make the button drive you to the view.
Hope this helps!
