How to filter column data with regex
  • Jan 18, 2021 5:39 AM UTC
  • 118 views
Hello, I am trying to filter observations in particular column which begins with SYS or ENG while counting (Number KPI). How can I do it with Celonis? I have read about MATCH_PROCESS_REGEX, but did not quite get it. Please help
Hi @1460044418,
you could use SUBSTRING( ) to filter on the specific text string and then apply an analysis, sheet, component filter.
Hopefully, that helps solve that issue!
Justin
