How to create OLAP Tables with sub-categories?
  • Feb 5, 2025 6:28 AM UTC
  • 202 views
utkarsh.rasto11
Level 2
Forum|alt.badge.img+5
As evident from the above image, there are further sub categories in the metrics column. Can we create an OLAP table in similar fashion?
You can still try to achieve something similar using the Pivot Table in Analysis. However, for both the Legacy and New View, this option is not yet available.
abhishek.chatu14
