How to build a Linear Gauge plot in a view
  • Feb 8, 2023 9:48 AM UTC
  • 130 views
dany.moual11
Level 5
Forum|alt.badge.img+7
Can someone help me with the YAML code or a reference for the implementation of a linear gauge graph like the one below in a View?
It was taken from a trycelonis example.
Thanks a lot,
Dany
Forum|alt.badge.img+3
  • Level 0
  • Feb 27, 2023 9:40 AM UTC
hi @dany.moual11  could you please check out this doc page on the views component:
https://docs.celonis.com/en/views-components.html
dany.moual11
Level 5
  • Level 5
  • Mar 1, 2023 9:29 AM UTC
Hi @ilmi.hajdi . I read the page and I was lost. But I found a solution using Rules in the Chart and defining some other KPIs. Thanks for your feedback
