How can you create a dropdown filter in a view to switch between AVG & MEDIAN?
  • Jun 21, 2022 8:29 AM UTC
  • 194 views
I would like to update a runtime variable with the value selected (either AVG or Median)
  • Jun 22, 2022 6:11 AM UTC
I never did it, but from similar experiences with variables I would:
Create a variable text called... I. don't know.. avg_or_median...
Set up a dropdown manual, 2 options. Each option sets the variable ave_or_median to either AVG or MEDIAN (or whatever is called the operation)
In your KPI's and PQL, use the variable ... like <%=avg_or_median%>(table.column)
Probably you will need some try and error.
Using KPI with parameters is another way to try, but I am not completely confident it will work
HTH
  • Jun 22, 2022 7:35 AM UTC
Thanks for the insights, however I was not able to find these options you mention (which I also know from Analyses) in the View.
  • Jun 22, 2022 7:43 AM UTC
My bad, I didn't realise that you were in views.
with Views you can use several buttons (one per option, in your case 2 buttons one with Avg and another with Median) image
Also a Input checkbox, then switching between the 2 values (but you need to edit yaml)
Hope it helps!
