How can i send a constant input to an Action Flow?
  • Aug 13, 2025 11:44 AM UTC
  • 164 views
marcelo.ferre11
Level 2
Forum|alt.badge.img+7
Hi Team,
I’m working on creating a generic Action Flow with a writeback module. Depending on the OLAP table, I need to send different inputs to select the correct table for the writeback.
jan.vajse12
Level 7
Forum|alt.badge.img+2
  • Level 7
  • Aug 15, 2025 12:19 PM UTC
Hi Marcelo,
if you need to set a constant variable within your action flow, you can use the actions Set variable  or Set multiple variable from the Tools options:
If you need to pass a variable with values depending on the data source, use the Inputs option on the upper ribbon.
How it will help you!
Regards
Jan
