How can I export Duration column in Case Explorer in days, instead of seconds?
  • Jul 24, 2022 12:28 PM UTC
  • 68 views
Hello all,
When exporting Case Explorer sheet to an xlsx file, the Duration column comes as seconds, despite showing in days when viewing on browser. So the viewers keep asking what this value is, is it possible that Duration column shows in days after export?
Regards, and thanks in advance.
Hi Emrah, thank you for reaching out! Can you please create a support case or write us an email at servicedesk@celonis.com and provide a screenshot of how the case Explorer is looking and the xlsx file. Many thanks for your collaboration on this matter Best regards, Rrezarta
