Hide zero-value entries in filters outside selected filter scope
  • Feb 9, 2026 10:33 AM UTC
  • 415 views
Hello everyone,
When a filter is applied (e.g., for a specific source system or company code), other filters still display values outside the selected scope with 0 values.
Is there a way to hide these values completely instead of showing them as 0?
Best answer by Amishee Choksi
Hi Chetan,
We cannot hide those values specifically, they will continue to show the 0 value.
Is there a specific reason you want to hide these values?
Hi Chetan,
subhayu.monda12
Level 4
Forum|alt.badge.img+17
You may try by using a Forced Filter https://docs.celonis.com/en/filter.html#id681788
If a regular filter is set as a sheet or component filter, the affected Dropdown and Button Dropdown components still show all available values. If only those values which respect the filter should be displayed and selectable, a forced filter can be used. Analysis filters are forced by default.
PQL goes something like this
FILTER FORCED "Table"."Country" IN ('DE','US');
