Filter with nested case when
  • Jul 13, 2026 12:25 PM UTC
  • 883 views
I am trying to create a view filter with case when nested in it.
It goes like this:
FILTER VBAP-FilteringField
CASE
WHEN COALESCE (Var1, ‘’) = ‘Open Order’ THEN =  ‘Open Order’
WHEN  COALESCE (Var1, ‘’) IN (‘Open Order’, ‘Missing Invoice’) THEN IN (‘Open Order’, ‘Missing Invoice’).
The issue is: in the beginning, when there is one value (‘Open Order’) resulted from the CASE WHEN statement, the filter works well. But when I expand the fomular, including the result as a list  (‘Open Order’, ‘Missing Invoice’) and need to use the Word “IN” instead of “=” for filtering, it throws an err in the formular.
Any suggestion how I can work around this?
Thank you!
gagan1
  • Community MVP
  • Jul 15, 2026 6:35 AM UTC
Edit: See ly.le’s comment below — a simple variable is the right approach here. My original suggestion is left for context only.
Hi ​@ly.le ,
The syntax fails because a PQL CASE WHEN statement can only return a scalar value (like a text string or a number..). It cannot dynamically output operators (= or IN) or structural lists ('A', 'B') inside the THEN clause.
To fix this, rebuild the logic using native boolean AND/OR blocks. This allows the PQL engine to evaluate the variable state first, and then apply the correct filter execution without breaking syntax rules -->
FILTER
COALESCE('${Var1}', '') = 'Open Order'
AND "VBAP"."FilteringField" = 'Open Order'
OR
COALESCE('${Var1}', '') = 'Missing Invoice'
AND "VBAP"."FilteringField" IN ('Open Order', 'Missing Invoice')
Replace
 ${Var1}
with your exact variable format if needed.
  • Level 2
  • Jul 15, 2026 1:30 PM UTC
Thank you for your reply! I still got the err after trying out your suggestion.
But I realized that I overcomplicated the thing. Since it is only single field I am applying the filter on, there is no need for CASE WHEN. I simply revised it as:
FILTER
"VBAP"."FilteringField" = ${var1}
And then let the users use the button to update the Var1.
One small note on your comment on the CASE WHEN returning only scalar: It actually can return a column. And because of this, I was surprise when it complained on a list in my formular.
gagan1
  • Community MVP
  • Jul 15, 2026 2:32 PM UTC
​@ly.le  Ah, thanks for the correction, I honestly didn’t know CASE WHEN could return a column like that. My bad.
Your button-variable approach is way cleaner anyway, glad you got it sorted.
