File connection not found
  • Sep 24, 2020 5:06 AM UTC
  • 90 views
Hi team, I am trying to upload a .csv file in to the Celonis Frontend datamodel. but everytime i do that press on reload, im getting a File connection not found error. I searched the community and i cannot seem to find a reason for this. Any suggestion would be helpful. Thank you.
Hey @rahulbhat, welcome to the Community and thanks for reaching out! I need more details to further investigate your problem: Can you specify which version of Celonis you are using? The upload of your csv. file works fine? Can you please send a screenshot of the error? In general, please be aware that the file upload limit is 1 GB per file. Best regards, Your Celonis Data Science Team
  • Oct 13, 2020 9:55 AM UTC
Hello. Thank you for the reply. I am currently using Celonis 4.5 The upload of .csv file works fine. After uploading , it gives an error of File Connection not found with one entry for .csv file.image1421495 54.9 KB
Hey @rahulbhat, thanks for sharing the information. Unfortunately, we still cant give you a clear answer on why this is not working correctly. As a workaround, Id like you to create a new data model and try to upload the .csv there. Otherwise, please open a ticket at our service desk - our employees will take care of your question with best knowledge. You can create a ticket via https://servicedesk.celonis.com or e-mail to servicedesk@celonis.com Best, Your Celonis Data Science Team
  • Oct 16, 2020 4:35 AM UTC
Hi @datascience, Il create a ticket for this. Thank you.
