Failure to Create Task Mining Project
  • Aug 4, 2026 7:45 AM UTC
  • 584 views
akshay_haridas
Level 5
Forum|alt.badge.img+2
Hey team,
I am going through the task mining course by celonis and as I follow through the course, I am unable to create a task mining project under the task mining session, every time when I create a task mining project it is created under data integration session instead of the project session in task mining. Have anyone faced a similar issue if yes what was the solution?
Thanks in advance,
Akshay
  • Celonaut
  • Aug 12, 2026 9:41 AM UTC
Hello Akshay, please send your issue to Academy Support so that we can help you.
akshay_haridas
Level 5
Hey ​@sara.ghola ,
The ticket has been raised but there is no solution for the same as of now. For your reference here is the ticket no. 00444647.
Thanks,
Akshay
