Extract weekday (Monday, Tuesday etc.) from a timestamp column not working. Always returning Thursday
  • Jul 8, 2024 1:06 PM UTC
  • 389 views
I have a date/time field, but somehow DAY_OF_WEEK(table.column) with %A as formatting always returns Thursday.
To strip the time, I'm using Round_day() which makes 2024-07-03 from a 2024-07-03 21:23:35 timestamp, but returns Thursday, but it should be Wednesday for July 3rd.
I can add a extra column from source tables, but prefer an easy PQL formula.
PS: I'm using the new view experience.
DAY_OF_WEEK ( ROUND_DAY( "eventproperties"."reportdate"))
weekday not working
mateusz.dudek14
Level 11
Forum|alt.badge.img+10
%a is working properly with date or timestamp. For example for date, or date with time it works good:
imageIt works bad because of day_of_week which outputs a int number 0-6. If you want to have proper weekday name based on a 0-6 int value use REMAP_VALUES+TO_STRING+DAY_OF_WEEK combo. I can assume it similar to setting formatting in Excel when date is int 1 (which is translated to 1s of January 1900), maybe because of Unix date system.
Code:
REMAP_VALUES(TO_STRING(DAY_OF_WEEK ("_CEL_AR_ACTIVITIES"."EVENTTIME")), [ '1' , 'Monday' ] , [ '2' , 'Something'] )
Example:
Mark as best answer if that helped :)
Mateusz Dudek
Hi Mateusz,
I added the weekday 'hardcoded' in my event property data. The simple %a or %A is not working, and the recode is not efficient.
Thanks for your answer, case closed for now.
joos.buijs
Forum|alt.badge.img+9
  • Level 10
  • Mar 2, 2026 3:35 PM UTC
Hi all,
I encountered the same issue and realized (only after submitting a support ticket of course :D) that the %a and %A formatting options take a date as input as mentioned by ​@mateusz.dudek14 .
What I want is a chart grouped by weekday (Sunday, Monday, etc.) to detect week patterns. The DAY_OF_WEEK() functions does exactly that but outputs numbers. For Dutch conversion I cooked up this PQL:
REMAP_VALUES ( to_string(DAY_OF_WEEK("L33_V_PERFMGT_CASE"."CASEEERSTEACTIVITEITDATUMTIJD")), ['0', 'zondag'], ['1','maandag'], ['1','maandag'], ['2','dinsdag'], ['3','woensdag'], ['4','donderdag'], ['5','vrijdag'], ['6','zaterdag'])
Update: remaining issue is that the values are not sorted correctly but show ‘randomly’ based on the dates that are coming from my data in the chart...
