extract data from Datapool without updating the Data Model in an Action Flow
  • Jan 29, 2025 9:23 AM UTC
  • 149 views
rebeca.ruipé
Level 1
Hello, How can I extract data from a field from a datapool table without updating the Data Model in an Action Flow?
Is it Possible?
Thanks
matt.witty13
I do not believe there is away to access data that isn’t in a data model. I imagine it is designed that way because of the sheer volume of data that would consume on the environment.
I’m curious what a use case for not using a data model table. Why would you want to develop an asset utilizing data which isn’t being used in a data model?
