Does delay in action flow count for the 1 hour limitation ?
  • Apr 5, 2023 12:43 PM UTC
  • 90 views
abhishek.chatu14
Hi for my use case requires me to add a 5-10 sec delay for each iteration of the data i.e. 6000 -7000 rows i.e. (6000* 5-10 sec)
I believe that adding this delay should not cross the 1 hours execution limitations. Any thoughts on the same ?
Hi Abhishek, would it be possible to open a ticket through our https://www.celopeers.com/s/support? Thank you for your collaboration.
