Display correct throughout times in Variant Explorer for cropped process flows
  • Nov 11, 2024 11:21 AM UTC
  • 94 views
lars.henni
Level 1
Hi all,
I try to display the correct throughout time for the process variant in the Variant Explorer (shown to the right for the graph/list) for cropped process flows.
I have cropped the process scope using CALC_CROP, both as a custom dimension and as a load script filter. The Variant Explorer returns the correct process of scope, but the total throughput time shown per process variant (shown to the right for the graph/list) is still based on the default CASE_START and CASE_END and not the process defined in the CALC_CROP.
I.e, the sum of throughput times between the displayed process steps is not the same as the total throughput time for the variant.
Is it possible to show the correct throughput time, given the process defined and visualized in CALC_CROP?
Thanks!
