Custom generated Column (Attribute) in Knowledge Model is not showing up in Studio
  • Jul 21, 2023 12:46 PM UTC
  • 109 views
florian.mrkvi
Level 7
Forum|alt.badge.img+3
in my knowledge model I have defined a new column on an existing table. When I buid a view on top of that model I can see the additional column in the table and can use it like every other column.
When I use the knowledge model as the base for a studio analysis the column is not showing up.
Did I miss something?
  • Level 8
  • Jul 25, 2023 11:24 AM UTC
Is it setup as a KPI or a record?
florian.mrkvi
Level 7
I defined it as a record. I thought I would get it as a new table column like in the views.
A KPI that is defined in the knowledge model is visible as such in the studio, this works ok.
