Configure Case Explorer - Case-centric
  • May 27, 2025 12:30 PM UTC
  • 201 views
leonardo.spina
Level 6
Hi all,
In the case explorer, in YAML or Views, how can I change the Throughput Time and use my own formula in PQL?
Thanks for helping.
Br,
Leonardo
Rami Agha Kassab
Level 3
Hello Leonardo,
try it as the following PQL
DURATION_BETWEEN(MIN("EVENTTIME"), MAX("EVENTTIME"), "DAYS")
Make sure to specify the event time of you activity accordingly
leonardo.spina
Level 6
Hi Rami,
Thank you for the formula. how do you input it in Case Explorer?
Br
