Color Mapping logic based on ‘like\\contains’ string
  • May 20, 2020 8:42 AM UTC
  • 117 views
Forum|alt.badge.img+10
Hello Celonis team, I would like to know how I can conditionally color the columns of a column component based on like\\contains logic? I am using round_month on my x-axis but I want to color all bars for 2019 separate for the ones from 2020. In my experience, color mapping will only allow me to set a color for the entire string in the dimension. Thank you.
  • Himalini Aklecha
Hello Himalini, unfortunately, this is currently not possible by using color mapping. However, you can try to use different KPIs (which result in a different bar) but filter only for those values where you want to have another color. Example: CASE WHEN VEKP.ERDAT >= {d2020-01-01} THEN VEKP.BRGEW END I hope this helps!
