Cluster right and wrong Process
  • Mar 28, 2020 10:42 AM UTC
  • 32 views
steven.bernd
Level 6
Hey community Id like to create a cluster in form of a OLAP table in Celonis in which I can select the right process, but also those IDs that go wrong through the process. for example: I have problems with the coding Now something about the Process: My process looks like f.ex. Activity A Start>Activity B -->Activity C -->Activity D -->Activity E>Activity F END For our department activity C and activity E is important. The other activities can be neglected. The right process is when activity C comes first and activity E comes later, not the other way around. The wrong process is,
  1. when activity E comes first and activity C comes later, exactly the wrong way round,
  2. if activity E is completely missing,
I think I need something like this, but it is not yet thought through to the end DISTINCT(CASE WHEN PROCESS EQUALS Activity C TO ANY TO Activity E --the order is still missing here THEN right process WHEN MATCH_ACTIVITIES(NODE[Activity C] EXCLUDING[Activity E]) OR PROCESS EQUALS Activity E TO ANY TO Activity C --the order is still missing here THEN wrong process ELSE END) can anyone help?
Hi, thanks for the detailed description. Can you please try following code: CASE WHEN PROCESS EQUALS Activity C TO ANY TO Activity E AND PROCESS NOT EQUALS Create Invoice TO ANY TO Activity C THEN Right Process WHEN PROCESS EQUALS Activity E TO ANY TO Activity C OR PROCESS NOT EQUALS Activity E THEN Wrong Process ELSE NULL END Best, Viana
