"Case-When" categories KPI not aggregating.
  • Aug 5, 2024 3:03 PM UTC
  • 98 views
marcin.konop13
Level 4
Hi Celopeers and Celonis team.
I have quite a conundrum that is bothering me quite a bit and I don't know what else to try.
I have a case-when kpi that creates a risk category for customers based on a set of parameters. It works perfectly for customer by customer basis.
But when I try to do any aggregations by the categories it always shows just one value.
In the below image you can see it in action. In one the KUNNR number is the dimension and the Category as the KPI, in the other, the Late payer is as dimension and COUNT(KUNNR) as a KPI.
Screenshotcategories
julia.bauer
Level 9
Hey @marcin.konop13 ,
could you please disclose your codings behind the two dimensions?
Thank you!
BR
Julia Bauer
marcin.konop13
Level 4
Thank you!
BR
Julia Bauer
Hi. Thanks for the reply. The late payer category is a simple case-when based on 3 KPIs:
CASE
WHEN
(KPI("invoices_late_over_30_days",{p1})
KPI("KPI_INVOICE_SUM_OPEN_AR"))
<=0.1
AND
KPI("avg_days_late")<0
THEN 'Early payer 1'
WHEN
<=0.1
AND
KPI("avg_days_late")<=5
THEN 'On time payer 1'
ELSE 'Other'
The 3 KPIs its utilizing are:
"invoices_late_over_30_days":
SUM(
 CASE WHEN
 DATEDIFF(dd,${VAR_DUE_DATE_CALC},TODAY()) >30 + {p1}
 AND "BSEG"."AUGDT" IS NULL
 THEN "BSEG"."WRBTR_CONVERTED"
 ELSE 0
"KPI_INVOICE_SUM_OPEN_AR":
SUM(
CASE WHEN KPI("FORMULA_INVOICE_INDICATOR_IS_CLEARED") = 0.0 THEN
KPI("FORMULA_INVOICE_CALC_CONVERT_TO_REPORTING_CURRENCY",'${{currency}}',
'Amount')
ELSE 0.0 END
(This one is from the regular Celonis KM from the marketplace)
"avg_days_late":
AVG(
 CASE WHEN
 DATEDIFF(dd,${VAR_DUE_DATE_CALC},TODAY()) >1
 THEN DATEDIFF(dd,${VAR_DUE_DATE_CALC},TODAY())
 ELSE 0
PS: The {p1} variable is insignificant as the issue persisted even before I added the parameter.
