Automation rate
  • Aug 29, 2019 11:15 AM UTC
  • 125 views
Hi all, were currently only considering user types to define which activities have been done automatically (batch user) and which have been processed manual (all other user types): 100.0*AVG(CASE WHEN _CEL_P2P_ACTIVITIES.USER_TYPE IN (<%=auto_user_type%>) THEN 1.0 ELSE 0.0 END) However, for our MRP runs which shall be also considered automated there is always a manual user in SAP. We can identify MRP runs by the doc type (EP) in combination with the PR creation indicator (B). Any suggestions how we can adjust above formula to also consider EP in combination with B as automated? Thanks Oli
joos.buijs
Forum|alt.badge.img+9
  • Level 10
  • Aug 29, 2019 1:09 PM UTC
Could you extend your CASE WHEN statement to include a second check whether the username is in a list of usernames? For example (I dont know the exact SAP table/column names): 100.0*AVG(CASE WHEN _CEL_P2P_ACTIVITIES.USER_TYPE IN (<%=auto_user_type%>) THEN 1.0 WHEN "_CEL_P2P_ACTIVITIES"."USERNAME" IN (<%=auto_user_name%> THEN 1.0 ELSE 0.0 END) Bonus suggestion: you dont need the 100.0* if you set the display format to % (with decimals). Hope this helps!
  • Level 5
  • Aug 30, 2019 11:44 AM UTC
Thanks for the fast feedback! However, the extension shall not be based on user names but on a combinantion of PR Creation Indicator (B) and on PO Document Type (EP). Ive tried to update the formula as follows but always receive the error message that tables _CEL_P2P_ACTIVITIES and EBAN do not have a common parent in the schema: 100.0*AVG( CASE WHEN _CEL_P2P_ACTIVITIES.ACTIVITY_EN NOT IN (<%=ActivitiesUsedInAutomationRate%>) THEN NULL WHEN _CEL_P2P_ACTIVITIES.ACTIVITY_EN IN (<%= ActivitiesUsedInAutomationRate %>) AND _CEL_P2P_ACTIVITIES.USER_TYPE IN (<%=auto_user_type%>) THEN 1.0 WHEN EKKO.BSART = EP AND EBAN.ESTKZ = B THEN 1.0 ELSE 0.0 END ) Any idea/suggestion how to solve? Thanks, Oli
Hey Oli, I think this problem is connected to the other question I just answered. To solve your problem, it probably should help to put the EBAN part of your statement into a Pull Function, most likely PU_COUNT should be used so here it goes: 100.0*AVG( CASE WHEN _CEL_P2P_ACTIVITIES.ACTIVITY_EN NOT IN (<%=ActivitiesUsedInAutomationRate%>) THEN NULL WHEN _CEL_P2P_ACTIVITIES.ACTIVITY_EN IN (<%= ActivitiesUsedInAutomationRate %>) AND _CEL_P2P_ACTIVITIES.USER_TYPE IN (<%=auto_user_type%>) THEN 1.0 WHEN EKKO.BSART = EP AND PU_COUNT(EKPO, EBAN.ESTKZ, EBAN.ESTKZ = B) > 0 THEN 1.0 ELSE 0.0 END ) Best Regards, Benedict Lang
  • Level 5
  • Sep 2, 2019 6:10 AM UTC
Great, thanks so much! That solves the problem indeed
