Action Flow + Skill: E-mailing with a .CSV Attachment (Wrong Format?)
  • Jun 24, 2022 9:24 AM UTC
  • 6 replies
  • 201 views
Good morning Everyone,
We have recently started to build an Action Flow that consists of emailing users regarding invoices that have Cash Discounts available.
We have managed to build it successfully up to the part where we want to have a .csv file in attachment.
As you can see here, the file that we get as an attachment has an odd encrypted format:
CSV Attachment Format
Could you please point us in the right direction?
Nothing we've found in the available documentation / Celopeers community has helped us tackle this
This is our Action Flow setup:
Celopeers_Action_Flow_SSThis is the Skill setup:
Celopeers_Skill_SS
Thank you so much in advance, we really appreciate it!
Vasco Carona
Best answer by Anonymous
To anyone else with this issue, we just had to add a base64() enclosing to the Text being generated by the "Create CSV" Bubble:
Resolved!
  • Answer
  • Jun 24, 2022 9:46 AM UTC
Resolved!
  • Jul 1, 2022 7:09 AM UTC
Resolved!
Thanks for the solution, that's appreciated :)
  • Aug 11, 2022 5:28 AM UTC
Did you have any performance Issues regarding the Celonis "Process Automation Skill"?. I did a very similar Actionflow set up then you, but when I increase my CSV columns to maybe 8 the Processautomation skill has a timeout error, however when using only 4 -5 columns it works perfectly
  • Aug 11, 2022 8:17 AM UTC
Hello Constantin,
We have not had any such issues, our largest .csv file has 19 Columns, so it seems that there might be an issue on your side!
Vasco Carona
Resolved!
Hi @vasco.caron11
I enclosed csv output in base64()
but the date format is incorrect
It is giving numbers/logarithm value instead of date format
Need help with this
bunyod.sap
Level 7
  • Level 7
  • Sep 16, 2023 5:23 PM UTC
@vasco.caron11 I am now struggling with this issue which you had one year ago 😟. I was wondering if you could share the blueprint of your action flow? Thnanks very much. Best, Bunyod
