Action Engine Migration to Studio Skills
  • Aug 4, 2021 8:06 AM UTC
  • 8 replies
  • 197 views
We are currently in the midst of migrating all our Analyses and Action Engines to Studio. Celonis provided with a functionality to seamlessly migrate the analyses to Studio.
Is there an easy way to migrate Action Engine Skills to Skills within Studio?
Thanks
Hi @miriam.luttr,
Maybe this Python script will work for you? You can execute it using the Machine Learning capabilities within Celonis.
pycelonis-examples/05_workflow_to_studio_skill_mover.ipynb at main · celonis/pycelonis-examples (github.com)
Forum|alt.badge.img+28
Hi @miriam.luttr,
  • Level 0
  • Nov 23, 2021 9:50 PM UTC
Hi Miriam,
did this script work? What exactly are you trying to migrate? Action Engine Skills have a different functionality than the new EMS capabilities so I believe you can't actually migrate the Action Engine Skills.
Kevin
  • Level 0
  • Nov 27, 2021 11:17 AM UTC
Addition: We are recommending using Action Flows going forward as this solution offers many more capabilities and it might be the case that support for Action Engine will be determined at some point.
Kevin
  • Level 0
  • Nov 27, 2021 11:18 AM UTC
  • Nov 29, 2021 8:31 AM UTC
We ended up re-creating our Alerts manually in Studio with Action Views and Profile Views. The Alert rules we're quite simple so we didn't bother with the python script. Thanks anyway @janpeter.van.d @kevin.flesc
  • Level 0
  • Nov 29, 2021 9:12 AM UTC
@miriam.luttr Great to hear it worked. Can you share how you did it here so others can benefit from it as well in case they have the same question? :) Would be great to provide your information for the community.
Kevin
gabriel.okaba11
For simple Alerts,
you could even have kept the skills in Action Engine and called them from Studio (select the action "Action Engine Sensor").
  • Nov 30, 2021 9:25 AM UTC
Thanks for the tip. @vasco.caron11
