Pie Chart Dimensions Issue
  • February 17, 2022
  • 5 replies
  • 19 views
In my current UseCase i do have the following issue:
I have five transporters. Each of the them transports 5 packages.
Therefore i do have 25 rows in my table.
I also have the time when the packages need to be delivered and when the transporter delivered them.
I want my pie-chart to show how many transporters delevered their entire load of packages on time and how many did deliver at least one package to late.
Forum|alt.badge.img+13
  • Level 7
  • February 21, 2022
Hi Andreas,
Try this setup:
Dimension:
CASE WHEN
PU_COUNT(
  DOMAIN_TABLE("TEST_csv"."TRANSPORTER_ID")
  ,"TEST_csv"."TRANSPORTER_ID"
  ,PU_COUNT(
    ,"TEST_csv"."PKG_ID"
    ,MINUTES_BETWEEN("TEST_csv"."ACTUAL","TEST_csv"."SLA") < 0
  ) > 0
) > 0 THEN 'TRANSPORTER WITH AT LEAST ONE PACKAGE DELIVERED LATE'
ELSE 'TRANSPORTER ON TIME'
KPI:
COUNT(DISTINCT "TEST_csv"."TRANSPORTER_ID")
SLA = need to be delivered
ACTUAL = is delivered
  • Level 7
  • February 21, 2022
Please upvote if helpful
  • Level 2
  • February 22, 2022
Hi Andreas,
Try this setup:
Dimension:
CASE WHEN
PU_COUNT(
  ,PU_COUNT(
  ) > 0
KPI:
Hi Eugene,
thanks for your efforts.
Unfortunately the query does not give me the right output.
Dimension:
CASE WHEN
PU_COUNT(DOMAIN_TABLE("ACTIVITIES"."CASE_ID")
  ,"ACTIVITIES"."CASE_ID"
  , PU_COUNT(
    ,"ACTIVITIES"."HANDLINGUNIT"
    ,MINUTES_BETWEEN ( "ACTIVITIES"."GEPLANTER_BEDARFSZEITPUNKT", "ACTIVITIES"."TIMESTAMP_QUIT" )<0
    )>0
  )>0 THEN 'to late' ELSE 'on time' END
KPI:
COUNT(DISTINCT "ACTIVITIES"."CASE_ID")
OUTPUT:
to late: 344
on time: 1
Desired Output:
to late: 30
on time: 315
best regards,
Andreas
  • Level 2
  • February 22, 2022
Hi Andreas,
Try this setup:
Dimension:
CASE WHEN
PU_COUNT(
  ,PU_COUNT(
  ) > 0
KPI:
The hint to create the query with the "DOMAIN_TABLE"-statement was worth gold!! Tahnks for that Eugene.
I now did it this way in the dimension:
CASE WHEN
PU_COUNT(DOMAIN_TABLE ( "ACTIVITIES"."CASE_ID"), "ACTIVITIES"."CASE_ID",
MINUTES_BETWEEN ( "ACTIVITIES"."GEPLANTER_BEDARFSZEITPUNKT", "ACTIVITIES"."TIMESTAMP_QUIT" )>0
)>0
THEN 'to late' else 'on time' end
  • Level 7
  • February 23, 2022
CASE WHEN
)>0
Oh, now that I see the actual table names - you can use the cases table instead of domain table with activity.case_key, it should yield the same result. In any case - glad you were able to make this work!
