Math problem (division)
  • November 17, 2023
  • 42 views
enrico.pugli12
Level 6
Forum|alt.badge.img+10
I am trying to calculate a kpi that represents the number of average daily recallers (i.e., people who call more than once in the same day).
The information is all in the same table, and I calculated the users (ID_Telefono) who for each day (ROUND_DAY(starttime)) made more than one call (UniqueID). The calculation was done with a CASE WHEN.
To get the daily average, I divided the result by separate counts of the days available to me (ROUND_DAY(starttime)).
(SUM (CASE WHEN
PU_COUNT(DOMAIN_TABLE("xcally_clean"."ID_Telefono", ROUND_DAY("xcally_clean"."starttime")), "xcally_clean"."uniqueid" )>1
THEN 1
(COUNT(DISTINCT(ROUND_DAY("xcally_clean"."starttime"))))
The problem is that the result is wrong. If I calculate denominator and numerator separately and divide them, I get 61, while if I leave the formulas on celonis, I get 142.
There is no common table problem because all the information is on one table (xcally_clean).
I attach screenshot with the details.
Can you help me?
Thanks
Best answer by dennis.pflug
not sure if this really solves the issue but have you tried GLOBAL function: GLOBAL (celonis.com)
(SUM (CASE WHEN
THEN 1
GLOBAL((COUNT(DISTINCT(ROUND_DAY("xcally_clean"."starttime")))))
dennis.pflug
Forum|alt.badge.img+7
  • Level 10
  • Answer
  • November 17, 2023
(SUM (CASE WHEN
THEN 1
enrico.pugli12
Level 6
Dennis,
you have right!!!
Thank you so much!😁
