I'm looking for the use cases using machine learning functions in the Celonis. Could you please share the information?
Basically Machine Learning workbench is not only about machine learning because of the ability to use Python.
A) General use cases
-GIT integration
-Scheduled transfer of the configuration between teams (release management)
-Checking / transforming data that's not possible with Vertica SQL or PQL
B) ML use cases
-Fraud Detection
-Predicting Behaviour
-Transportation Optimization
-Process Automation
I would focused on easy ML use-cases for python and then watch out for the maximum memory limitation (default: 5gb, it can be upgraded by Celonis if needed). You can get the data with PyCelonis + Pandas.
Some ready-to go examples were also avaiable on Celonis Academy:
https://academy.celonis.com/learn/course/machine-learning-duplicate-checker/machine-learning-duplicate-checker
Mateusz Dudek
