Yes, you can assign the dropdown selection to a variable and use that variable in case when clause in the column chart.
Thank you for your answer. And how can I integrate the statement CASE WHEN "drop down is empty" THEN...
is there a syntax for it or do I miss something here?
Best regards
Best regards
case when <%variable> is null then ... end
Unfortunately this doesnt work. An error occurs when no value is selected in the dropdown menu. The error disappears after I select a value.
Sorry, please ignore earlier reply.
Below method will work, but it will apply the filter to the entire analysis and not to a specific component.
- Limit the number of in column chart to 5 and add sorting appropriately
- Dimension should be the vendor column
- You have to add dropdown (under selection components) component (NOT button dropdown under design components) and dropdown items should be the vendor column
