I am having a data connection from ORACLE EBS. Is it possible to enable replication cockpit for this connection? if possible how to do it? Do we need to enable Realtime extraction from Oracle end?
  • Aug 2, 2023 6:31 AM UTC
  • 126 views
Forum|alt.badge.img+2
  • Level 8
  • Aug 2, 2023 10:21 AM UTC
Not sure if supported as yet.
Replication Cockpit (RC) and Data Jobs (DJ) are 2 different tools that basically serve the same purpose - define and orchestrate how the data is fetched from the source system to the EMS. RC does not support all of the ETL use cases yet, and it has to co-exist with the DJs to enable a fully functional data pipeline.
https://docs.celonis.com/en/how-to-design-the-data-pipeline--replications-vs-data-jobs.html
That said worth setting up and trying. I am sure someone in the community would be interested.
Oh. then need to connect with ERP IT team and Celonis IT team.
