How to upload data(in csv format) to studio?
Hi Gaurav, on the side panel, select 'Data' -> 'Data Integration' -> (Choose the relevant Data Pool; or create a one one via top right button) -> 'File Uploads' -> Drop your CSV there
Then you can specify/select the relevant columns (e.g. case ID / timestamp / activity).
That helped. Thanks for quick help
Hello, I uploaded the csv files and now I have to do the data processing. I have 3 csv files uploaded. How should I do the transformation. Since Execution changed to integrity I do not know how to specify columns etc. Can you help?
