How to save draft of data pool using API or Pycelonis?
  • April 13, 2023
  • 35 views
Forum|alt.badge.img+5
I need to schedule publishing of data pool draft. There is the function publish() for packages in PyCelonis but I haven't found something similar for data pool in API documentation or in PyCelonis.
Is there any way I could run saving of data pool draft or adding a new version for unpublished drafts? Is sync of data pool an option for this?
Thank you very much!
Forum|alt.badge.img+3
  • Level 0
  • June 22, 2023
Hi Vira,
Thank you for reaching to us.
In order to be able to assist you further, we would suggest to send an email to servicedesk@celonis.com with detailed description.
We will gladly help you.
Thank you in advance.
