How to convert my system report details to EMS (CASE ID , Activities , Time stamp ) format for uploading in CSV/XLSX Upload screen
  • February 22, 2023
  • 1 view
Dear All,
In my system report , CASE ID - Truck No , Activities , Time stamp are in column because of this , Error found in CSV/XLSX Upload screen.
How to convert my report to upload in EMS format.
Regards
Rajkumar Pitchiah CMILT , CLTD , LSSBB
Chief Digital Transformation officer – CDO
http://www.inspiretechnopark.com
janpeter.van.d
Forum|alt.badge.img+26
Hi @rajkumar.pitch13,
Celonis has an integrated ETL pipeline, standing for Extract, Transform and Load. If your dataset is not yet in the format that Celonis would like to have, you can use Transformations to adjust your tables (and create activity tables) before Loading them in data models.
Transformations are done using Data Jobs in the Data Integration section, see Transformations (celonis.com) and Add an Activity to the Activity Table | Celonis Academy.
There is not one single query that creates a activity table, it depends on your source data. If you want to learn how to do this, I would suggest to follow the track 'Transform Data' (link: https://academy.celonis.com/courses/transform)
Thanks Jan-peter van der steege for your guidance and will check in my C4C system and come back,
