How to apply delta filters with Business Central APIs?
  • November 30, 2023
  • 35 views
chaitenya.varsh
Level 3
Forum|alt.badge.img+5
Hello Chaitenya,
The best practice is to use dynamic parameters with the operation type `FIND_MAX` for delta filters as they indicate the maximum value of a defined column. If the indicated table does not exist in the EMS or is empty, the `DEFINED VALUE` is utilized.
You can include filters for the delta links, which are typically based on the `GET` query call. When calling the API with the `deltaLink` to get the changes, each entity that previously didn't match the filter criteria, but matches it now, returns as an "add" entity
chaitenya.varsh
Level 3
Hi Harshit,
I did try using 'Find_Max' but I was unsuccessful.
imageimage If you have any other suggestion, please do let me know.
Thanks for your help.
