How do you manipulate a timestamp in SQL?
  • March 6, 2023
  • 25 views
Hello all,
I have tried to manipulate the timestamp in SQL, which worked on our Oracle server, but seems to have no effect on the back end in EMS. I suspect there is some kind of time zone problem? I have attached a few screenshots.
The timestamp should have the following format:
Original: YYYY-MM-DD 00:00:00 --> manipulated YYYY-MM-DD 23:45:00
Thanks for your answers in advance.
With kind regards
Christoph
EMS not working
Local Database the SQL query worksimage
  • Level 9
  • March 6, 2023
Hey Christoph,
It looks like you are trying several different methods to manipulate the timestamps. Seeing as you want to achieve the 23:45 version, wouldn't it make more sense to add 1425 minutes instead of 1485. Now you are adding a day and 45 minutes to your queries.
It's interesting to me that the 'hallo' and 'test' queries actually show the 23:45:00 time, might this have something to do with timezones in some way?
Question: Do you want to achieve your transformation of timestamps in SQL or in Celonis directly?
Maurits
