How can I check my trial license for Celonis Process Mining & Task Mining
  • October 18, 2022
  • 56 views
Dear Sir/Madam,
Currently, I'm using the trial account of Celonis Process Mining and Celonis Task Mining. And I'm installing "Celonis Task Mining" and "Celonis Task Mining - Configuration Editor" on my laptop also. I have some questions:s How I can check the information on my trial license? And how long can I use this software on my laptop? Thanks so much.
Forum|alt.badge.img+10
  • Level 6
  • October 18, 2022
In the EMD, under Admin & Settings, license. That should provide info on your license
  • Level 1
  • October 18, 2022
Thanks so much, @roan.schuu13 . I can see it now.
