help.celonis.de
  • December 15, 2021
  • 4 views
Hallo. I need a PQL Function Library. I have found the page, where it is stored. However, I cannot download it. The webpage is https://help.celonis.de
I cannot figure out where I can find the library. Since Celonis uses their own language, even it is very similar to SQL, it is much better to have the library where you can look up for a function or command.
Thanks in advance.
P.S: Regarding the version of Celonis, I have no clue. I know that we use a web-hosted Celonis.
janpeter.van.d
Forum|alt.badge.img+26
Hi @grigory.ramic,
There are two locations where you can find all the help you need:
  • In the PQL editor itself you find the button 'PQL Reference' in the upper right corner (see screenshot below).
pql_reference
Once you are on the Celonis help pages, you can download a PDF version of it using the menu in the upper right corner (see screenshot below).
pql_library_pdf
