Formula excel for PQL
  • April 19, 2024
  • 50 views
I need some help guys, I want to add up the day's payments to generate an accrual. Example: Day 01 $100, Day 2 $200 Day 03 $300
In the amount I want, I would do it like this: on day 1, $100, on day 2, $300, on day 3, $600.
But I don't know how to do it, below in Excel how it was done.This needs to be per month. So it adds up only within the month when the month ends it resets and dnv starts. I don't know if it's clear, but you can try to clarify better.
Excel:
imagemy attempt at PQL
SUM (
 CASE WHEN "BSEG"."AUGDT" >="BSEG"."AUGDT" THEN KPI("valor_acumulado") + "BSEG"."DMBTR" ELSE
 "BSEG"."DMBTR"
valor_acumulado = CASE WHEN
"BSEG"."AUGDT" >= "BSEG"."AUGDT" THEN "BSEG"."DMBTR" END
Sverre Klein
Forum|alt.badge.img+14
Hi @douglas.henri,
I think you can solve this using RUNNING_TOTAL or RUNNING_SUM (not quite sure which is applicable in your case) and using the ROUND_MONTH operator to calculate the accrual for every month.
OLAP TABLE:
Dimension:
ROUND_MONTH("ACTIVITIES_TABLE_PO"."EVENT_TIME")
KPI:
RUNNING_TOTAL(SUM("CASE_TABLE_PO"."CUMULATIVE_NET_WORTH"))
FILTER:
FILTER YEAR("ACTIVITIES_TABLE_PO"."EVENT_TIME") = 2018
There are most likely smarter ways to go about this, but hopefully this gets you in the right track. 😊
Sverre Klein
Cool, thanks Sverre, I'll test it. It already gave me better guidance on which function to use.
Sverre Klein
No problem! Please keep me up-to-date if you potentially solved it or need more help 😊
dxb.miner
Level 5
  • Level 5
  • October 25, 2024
@douglas.henri
Instead of using the Activity Event time in the dimension, use some date column which is unique for each case and based on which date you want to generate the running sum. Else if you use event time then one DMBTR will be repeated in multiple months.
