Filter case when (ELSE)
  • May 3, 2023 12:59 PM UTC
  • 165 views
I want to create a filter of an ELSE inside my condition.
The  ELSE 'Área Não Aderente'. Below script. I want to bring only the data from this ELSE, which would be the opposite of my condition below.
CASE WHEN
  ("EKKO"."BSART" LIKE 'Y%' OR "EKKO"."BSART" LIKE 'PE' OR ("EKKO"."BSART" LIKE 'Z%' AND "EKKO"."BSART" NOT IN ('ZCG','ZPM', 'ZCAT')))
  AND
  ("EKKO"."EKGRP" LIKE 'I%' OR "EKKO"."EKGRP" IN_LIKE ('%1I','%2I','%3I','%4I','%5I','%6I','%7I','%8I','%9I') OR "EKKO"."EKGRP" LIKE 'A%' OR "EKKO"."EKGRP" LIKE '01A')
 THEN -- Pedido por Área
  CASE WHEN
  PU_COUNT("EKKO", "EKPO"."MATNR", "EKPO"."MATNR" IN_LIKE ('%3001009%', '%3000926%', '%3000927%'))>0 -- Cadastro de Material
  OR
  (PU_COUNT("EKKO", "EKPO"."MATKL", "EKPO"."MATKL" IN ('GI001710A'))>0 -- Grupo de Mercadoria
   AND
  "EKKO"."EKGRP" IN ('I09')) -- Grupo de Comprador
  OR
  "EKKO"."EKGRP" IN ('I38', 'I13','I12') -- Grupo de Comprador
  OR
  "EKKO"."Z_BSGRU" IN ('INT')
  AND
  "PO_LFB1"."FDGRV" IN ('FPREL') -- Contratos Intercompany
  THEN 'Área Aderente'
 ELSE 'Supply'
I need to filter only this condition, which would be the opposite of my condition above (ELSE)
Thanks.
Forum|alt.badge.img+27
Hi @douglas.henri,
If you are using 'Saved Formulas' (Studio Analysis) or 'KPIs' (Studio Knowledge Model), it is very easy to nest multiple statements.
In this case, your formula will become something like:
FILTER KPI("your kpi name here") = 'Área Não Aderente';
If it should be the opposite, use != instead of =.
Hopefully this helps.
Hi @douglas.henri,
Many thanks for your help as always Jan-Peter !
