Filter a case when condition
  • April 27, 2023
  • 92 views
I want to create a filter of an ELSE inside my condition.
The   ELSE 'Área Não Aderente'. Below script. I want to bring only the data from this ELSE, which would be the opposite of my condition below.
CASE WHEN
    ("EKKO"."BSART" LIKE 'Y%' OR "EKKO"."BSART" LIKE 'PE' OR ("EKKO"."BSART" LIKE 'Z%' AND "EKKO"."BSART" NOT IN ('ZCG','ZPM', 'ZCAT')))
    AND
    ("EKKO"."EKGRP" LIKE 'I%' OR "EKKO"."EKGRP" IN_LIKE ('%1I','%2I','%3I','%4I','%5I','%6I','%7I','%8I','%9I') OR "EKKO"."EKGRP" LIKE 'A%' OR "EKKO"."EKGRP" LIKE '01A')
  THEN -- Pedido por Área
    CASE WHEN
    PU_COUNT("EKKO", "EKPO"."MATNR", "EKPO"."MATNR" IN_LIKE ('%3001009%', '%3000926%', '%3000927%'))>0 -- Cadastro de Material
    OR
    (PU_COUNT("EKKO", "EKPO"."MATKL", "EKPO"."MATKL" IN ('GI001710A'))>0 -- Grupo de Mercadoria
      AND
    "EKKO"."EKGRP" IN ('I09')) -- Grupo de Comprador
    OR
    "EKKO"."EKGRP" IN ('I38', 'I13','I12') -- Grupo de Comprador
    OR
    "EKKO"."Z_BSGRU" IN ('INT')
    AND
    "PO_LFB1"."FDGRV" IN ('FPREL') -- Contratos Intercompany
    THEN 'Área Aderente'
  ELSE 'Supply'
Thanks.
The second 'Case When' statement is a part of the first one or is it a separate condition?
so basically :
1st case when-
then-- Pedido por Área
If the second 'Case When' statement is a part of the first one it should be written after 'Then'
If it's not a part of it,
Don't write Case when again, only 'When' should work.
CASE WHEN
  AND
  WHEN
  PU_COUNT("EKKO", "EKPO"."MATNR", "EKPO"."MATNR" IN_LIKE ('%3001009%', '%3000926%', '%3000927%'))>0 -- Cadastro de Material.........continued
Let me know if I am getting anything wrong.
Thanks
  • Level 7
  • April 28, 2023
so basically :
1st case when-
CASE WHEN
  AND
  WHEN
Thanks
Hi Dyvian, yes, the second is part of the first. I understand your placement.Thanks, i made the adjustment in WHEN
What I need is to create a filter, which brings me the condition  ELSE 'Área Não Aderente'.
kailash.potha12
You can try this
FILTER DOMAIN
-- Your Entire Case when statement --
IN ( 'Área Não Aderente' )
Kailash, thank you very much.
