Extracting Objects and Events in Python
  • March 7, 2025
  • 147 views
matt.witty13
Hi Celonis Community,
I’m trying to get a better understanding of what is in the OCPM Catalog. I’m hoping to extract all the objects and events, their attributes, etc. and build out some documentation in the event I need to adopt the OOTB solutions.
There doesn’t seem to be an export button or a way to pull out that information. Has anyone found a way to get this information out of Celonis?
Thanks!
Matt!
janpeter.van.d
Forum|alt.badge.img+26
Hi ​@matt.witty13
Nice to see you here too ;)
Using the OCPM migration notebook of Celonis, all objects and events are backed-up temporarily, which you can access later as separate JSON files. The markup is not very readable, but with some simple transformations, this should be doable.
matt.witty13
  • Level 10
  • March 18, 2025
Hi ​@matt.witty13
Hmm I don’t have that. That something I just need to reach out to my VE for or is there a github repository I need to access? Would love to build out a script that puts all of that into a digestible document.
manuel.wetze
Level 9
I got a pdf from my VE describing how to access this tool.
Behind the scenes it is a github repo. Not sure how they handle the access. But for sure I was able to clone it from within the machine Learning Workbench.
