Execution error: ERROR: Function catalog.timestampadd(unknown, int, time) does not exist, or permission is denied for catalog.timestampadd(unknown, int, time)
  • November 8, 2022
  • 5 replies
  • 69 views
I am working on a dummy data and while executing the vertica sql code, getting above error.Can anyone please help me with this.
Not all the functions of Vertica SQL are ported to Celonis. For example MILLISECONDS() does not work
You will need some "try-and-error" to find which function is ported and can help you
For example recently we used EXTRACT(MILLISECONDS FROM TIMESTAMP) to get that info
HTH
abhishek.chatu14
Try using the following
ADD_DAYS
ADD_MONTHS
ADD_SECONDS
TIMESTAMPADD is supported by Celonis however not sure why you have a catalog.timestampadd can you help us with a screenshot of your query ?
ADD_DAYS
ADD_MONTHS
ADD_SECONDS
Dear Abhishek,
please find the below code
Insert into "Contactcentre_Activity_table"  (     "Case_key",     "Activity_name",     "Event_time",     "Sorting"  )   SELECT  "Contactcentre_Case_table"."CALLID" as Case_key, 'Call Ring' as "Activity Name", CASE WHEN        TIMESTAMPADD(S,        DATEDIFF(S,'00:00:00',"RING TIME"::TIME),        (TIMESTAMPADD(S,        DATEDIFF(S,'00:00:00',"QUEUE TIME"::TIME),        "START TIME"))):: TIME >= (TIMESTAMPADD(S,        DATEDIFF(S,'00:00:00',"QUEUE TIME"::TIME),        "START TIME") :: TIME)      THEN        ("START DATE" :: DATE || ' ' ||        TIMESTAMPADD(S,        DATEDIFF(S,'00:00:00',"RING TIME"::TIME),        (TIMESTAMPADD(S,        DATEDIFF(S,'00:00:00',"QUEUE TIME"::TIME),        "START TIME"))        :: TIME)) :: TIMESTAMP      ELSE         ("START DATE" :: DATE + 1 || ' ' ||        TIMESTAMPADD(S,        DATEDIFF(S,'00:00:00',"RING TIME"::TIME),        (TIMESTAMPADD(S,        DATEDIFF(S,'00:00:00',"QUEUE TIME"::TIME),        "START TIME"))        :: TIME)) :: TIMESTAMP        END,  30 as Sorting from Contactcentre_Case_table;
HTH
Thank you will check it
abhishek.chatu14
Dear Abhishek,
Hi here are few things you are missing, lets say you want to add 10 seconds, this is what the query would look like
TIMESTAMPADD(s,10,TO_DATE('00:00:00','hh:mm:ss'))
So the first parameter is your datepart(in this example seconds) ,
the second parameter is the time you want to add (in this example 10 seconds) and the third parameter is the date field (in this example 00:00:00).
Now in your case I see four parameters
TIMESTAMPADD(
S, -> 1
DATEDIFF(S,'00:00:00',"RING TIME"::TIME), -> 2
(TIMESTAMPADD(S,DATEDIFF(S,'00:00:00',"QUEUE TIME"::TIME), ->3
"START TIME")): TIME) -> 4
Can you validate the same ?
