Error in formula using variable
  • Jan 16, 2024 4:08 PM UTC
  • 174 views
Hi there!
I've a problem using a variable in a formula of OLAP_TABLE.
I've two variables (Interv_1, prueba_var1) text/replacement Type, with values:
Interv_1=OTHER
Prueba_var1=3
image.pngIf i want to use it in a text component, with variable "prueba_var1" is OK,
imagebut if i use the Variable "Interv_1" i have a formula error.
imageI don't understand why.....
Thanks in advance
Hi @juan.gomez12,
It looks like Celonis thinks you are referring to a table instead of a simple piece of text/string. You could solve this in two manners:
  1. Add two single quotes around the text in your variable. By doing it here, you prevent also issues in other components.image
  2. In your formula, you could add two single quotes to parse the variable as a string. image
Forum|alt.badge.img+28
Hi @juan.gomez12,
  • Jan 16, 2024 5:05 PM UTC
Thanks a lot Jan-Peter!! And too fast!!
Was sooooo easy..... :)
Best Regards!
Best Regards!
Happy to help @juan.gomez12! Please accept the answer to help fellow peers in finding their answers.
