Enable searching project names
  • Aug 16, 2019 11:57 AM UTC
  • 105 views
Hi Celonis Community, were currently using Celonis 4.5 and have a large number of projects. At this point it would be very helpful to be able to search for a certain project. Unfortunately the search only supports folders, analysis and data models within the projects. Have I overlooked a way to do search projects? Otherwise Id appreciate some feedback if others would find this helpful as well. Best, David
