Duplicate checker using Pycelonis not possible !
  • April 23, 2024
  • 36 views
Hello everyone
I am trying to perform a duplicate checking of vendor master in the machine learning module following the tutorial in the link:
https://celonis.github.io/pycelonis/1.6.0/tutorials/data_deduplication/00_Tutorial_Duplicate_Checking/
The problem i encounter is that all the libraries used in this tutorial seem to not function in the new version of Pycelonis 2.8.0
Is there any new tutorial for the data deduplication with Pycelonis ? otherwise how can i perform that using python without calling the library shown in the tutorial ?
Any help will be extremely appreciated :)
Omar
Hi Omar,
It appears that Celonis EMS now offers a dedicated duplicate checker app in the marketplace. You can explore this option, although it will require adjustments to your existing configuration and setup.
Alternatively, if you’re looking for a quick temporary fix, you could consider downloading the
data_deduplication package from your older PyCelonis version and using it locally.
