Is there some kind of limit how many columns can be visible in the column chart? I have a table, in which I wanted to visualize activity count 13 types of cases per date. When I create 10 of them, the column bars are barely visible. If I add next kpi, then the bars disappear.
Is there some option to show all 13 kpi at the same time in column format?
I know I can change some of them to line axis, etc. but would prefer columns for all of them
I also know about "stacked on primary axis" option, but wanted to know if I can have separate columns
