Can anyone help with the SAP tables required for Master Data Management process mining ?
  • February 28, 2022
  • 24 views
Forum|alt.badge.img+10
Hi Saravanan, Thank you for reaching out. You can find all the information for Connector Table Requirements at the following link https://docs.celonis.com/en/marketplace/table-requirements.html. Thank you for your patience and understanding. Best regards, Valmira Abdiu
