Calculate time between two activities without a third being in between
  • December 12, 2023
  • 67 views
enrico.pugli12
Level 6
Forum|alt.badge.img+10
Hello everyone,
I should create two KPIs: average times between two activities.
1) the first one between activity A and activity B, in cases where activity C is not between these two activities
2) the second between activity A and activity C, in cases where activity B is not between these two activities.
So in a nutshell: the time between activity A and activity B, when the latter comes before C, and the time between activity A and activity C, when the latter comes before B.
I leave a diagram to explain better.
When there are only A and C without B, or only A and B without C it is very easy, but I cannot create when there are all 3.
Can you help me?
Thanks
Hi, could you please check if using ACTIVITY_LEAD helps? If not, I would suggest creating a support ticket.
enrico.pugli12
Level 6
Hi Keiko,
thank you for your response.
However, I don't think I understand how to use your suggestion.
I read the definition and usage of ACTIVITY_LEAD and I think I understood that to use it I need to know the exact location of the activity.
Unfortunately, between activities A, B and C there can be n different activities, and for each case they can be different, so I don't think I can use it.
Am I missing something?
Thank you
Hi Enrico, thanks for your response. I would suggest creating a support ticket by providing the actual activity data.
enrico.pugli12
Level 6
Since no one was able to help me and I was able, after several trials, to achieve a good result, I am reporting it here for anyone who had the same problem:
CASE WHEN PROCESS EQUALS 'A' AND PROCESS EQUALS 'B' AND PROCESS NOT EQUALS 'C'
THEN CALC_THROUGHPUT(FIRST_OCCURRENCE['A'] TO FIRST_OCCURRENCE['B'], REMAP_TIMESTAMPS("Activity"."timestamp", MINUTES))
WHEN PROCESS EQUALS 'A' AND PROCESS EQUALS 'B' AND PROCESS EQUALS 'C'
AND CALC_THROUGHPUT(FIRST_OCCURRENCE['A'] TO FIRST_OCCURRENCE['B'], REMAP_TIMESTAMPS("Activity"."timestamp", MINUTES)) < CALC_THROUGHPUT(FIRST_OCCURRENCE['A'] TO FIRST_OCCURRENCE['C'], REMAP_TIMESTAMPS("Activity"."timestamp", MINUTES))
For the complementary indicator, I reversed 'B' with 'C'
