Calculate Throughput Times between Activities and ignoring all cases if it touched a certain Activitiy
  • August 8, 2023
  • 110 views
milan.eric
Level 6
for some reason I can´t find any solution online for this problem. It is probably out there but I cant find it.
I simply want to showcase the following:
The Average throughput time between Activity A and C, but ignore all cases where it touched Activity B inbetween.
This feels like a very easy task but I can´t seem to find how to filter out Activity B.
Basically I thought it would like this:
AVG (
 CALC_THROUGHPUT (
  FIRST_OCCURRENCE [ 'A' ]
  TO
  LAST_OCCURRENCE [ 'C' ] ,
  REMAP_TIMESTAMPS ( "_CEL_O2C_ACTIVITIES"."EVENTTIME" , DAYS )
And then in the component filter:
FILTER "_CEL_O2C_ACTIVITIES"."ACTIVITY_EN" NOT IN ('B')
This obviously doesn´t work so I am here.
Maybe someone can answer me this rather simple question I suppose.
Thanks!
Best answer by tobias.boehm12
Hi Milan,
one way to check for a specific activity would be 'Process equals'.
You could use:
AVG(
  CASE WHEN PROCESS NOT EQUALS 'B'
    THEN CALC_THROUGHPUT ( FIRST_OCCURRENCE['A'] TO LAST_OCCURRENCE['C'], REMAP_TIMESTAMPS ( "_CEL_O2C_ACTIVITIES"."EVENTTIME", DAYS ) )
    ELSE NULL
to avoid the component filter or use a component filter: " FILTER PROCESS NOT EQUALS 'B' " for your own KPI above.
BR,
Tobias
Hi Milan,
You could use:
AVG(
    ELSE NULL
BR,
Tobias
milan.eric
Level 6
  • Level 6
  • August 31, 2023
Hi Milan,
You could use:
AVG(
    ELSE NULL
BR,
Tobias
Thank you it worked! Sorry for the late reply :) Forgot to answer back then when I used your answer!
