Writing/Modifying transformation codes (SQL) within data jobs using pycelonis in Machine Learning Workbench
  • Jun 15, 2026 1:10 PM UTC
  • 403 views
Pratheeksha
Level 5
I am able to retrieve the SQL transformation codes from the datajobs into Machine Learning workbench using pycelonis. But can I modify/write a new SQL code within the transformation directly in Machine learning workbench or is there no option for that?
Please provide some clarity one this.
m.sanchezmedina
Hi Pratheeksha,
Have you tried the `task.update_statement()` function from pycelonis? Here is the documentation for it.
Some dummy code:
celonis = get_celonis()
data_pool = celonis.data_integration.get_data_pool("Data Pool ID")
data_job = data_pool.get_jobs("Data Job ID")
# Get the existing transformation
task = data_job.get_task("Transformation ID")
# Read current SQL
old_sql = task.get_statement()
print(old_sql)
# Overwrite with new SQL
new_sql = """
DROP TABLE IF EXISTS MY_TABLE;
CREATE TABLE MY_TABLE AS
SELECT *
FROM SOURCE_TABLE;
task.update_statement(new_sql)
# Optional: verify
print(task.get_statement())
# Execute the job or only selected transformations
data_job.execute()
